Command Cancel Button
I have an Addins which creates a command with different inputs.
This command has an Ok and a Cancel button, I have 2 questions:
  1. How can I hide the cancel button? I found a reference in the manual (here) to isCancelButtonVisible property, but it seems that it doesn't really exist. CancelButton.PNG
  2. How can I register a callback for Cancel button? For the 'Ok' button there's the 'execute' event. For cancel I tried the 'destroy' event, but it's not called on 'Cancel', just on destroy (as the name says!). I don't wanna destroy the button, which is always there in the toolbar, but I need to cleanup some things if the user press cancel...
Thanks for the reply.
kandennti
Hi @Anonymous .
Probably the isCancelButtonVisible property does not exist.
When I tried it, the destroy event was called by both the OK and Cancel buttons.
In order to determine which button was pressed, I prepared a variable with a large scope and tried to determine whether the Execute event was called or not.
# Fusion360API Python Addin
import adsk.core, adsk.fusion, traceback
_app = None
_ui  = None
_handlers = []
_isSelectedCancel = True #Record that the Cancel button was pressed.
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            global _handlers
            cmd = adsk.core.Command.cast(args.command)
            inputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            inputs.addTextBoxCommandInput('test', 'test', '-', 1, True)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        dumpMsg('Call Execute Event')
        global _isSelectedCancel
        _isSelectedCancel = False
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        dumpMsg('Call Destroy Event')
        global _ui, _isSelectedCancel
        msg = 'Cancel' if _isSelectedCancel else 'OK'
        _ui.messageBox(f'Selected {msg} Button')
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('Test')
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition('Test', 'Test', 'Test')
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
def stop(context):
    ui = None
    try:
        ui  = app.userInterface
        ui.messageBox('Stop addin')
    except:
        if ui:
def dumpMsg(msg :str):
    adsk.core.Application.get().userInterface.palettes.itemById('TextCommands').writeText(str(msg))
I don't know the content, but if you use the executePreview event, you may not need to clean up.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-dbecfaf8-9bb6-4e40-9df3-0a3e48136a4b
Hi @kandennti, thanks for the reply.
Actually in your case is called because you are using a script, I guess.
In my case, the button still always open (never calls destroy, also in case of ok), because it's a command in the toolbar, and it creates command inputs when its createdHandler is executed. It's an addin.
The destroy is called only when I stop the addin.
Anyway, I solved by resetting the variables at the beginning of the "createHandler".
Thanks again for the reply.
No way, it works also in my case when I hit cancel.
I should've missed something when I tried, but it was late last time 😉
Thanks again
