Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Combine Does Not Work, I suspect some overlap issues of adjacent touching profiles and solids.
2 REPLIES 2
tperam
218 Views, 2 Replies
Combine Does Not Work, I suspect because Fusion 360 Lofts Extrudes are making some overlap issues of adjacent touching profiles and solids.
How can I fix this?
Should I Shift and or Widen the Lofts and Extrudes Profiles or Thicken the Solids by a small increment in the overlap edges or areas?
Does Fusion 360 offer some feature which does this?
Thurai
Labels (1)
2 REPLIES 2
BrianEkins
in reply to: tperam
Coincident, non-analytic surfaces can be a challenge for any modeler. It's best to make sure they fully intersect rather than just be coincident. Without seeing what you're trying to model, it's difficult to be any more specific.
Brian Ekins
tperam
in reply to: BrianEkins
Hi Brian,
I Created a pair of Simple Non Intersecting Extrudes API to illustrate the issue. But they combined okay.
Thanks for your feedback, I understand that they have to be intersecting.
Thurai
Technology Administrators
