Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Combine cut script problem
1 REPLY 1
brad.bylls
209 Views, 1 Reply
I am creating an add-in and am having a problem with this script.
I don't find any examples for this and I am floundering on how to get it done.
What I want is for the user to pick multiple target bodies and multiple tool bodies.
When the user clicks 'Create the Cuts' that is what is supposed to happen (multiple cuts)
When using the Fusion command, you are only allowed 1 target body and for what I am working on that takes too long.
Being fairly new to the API and the documentation, I am floundering.
Can someone please help.
    def on_execute(self, command, inputs, args, input_values):
        x = 0
        y = 0
        target_input = inputs.itemById('target')
        targets = target_input.selectionFilters
        tool_input = inputs.itemById('tool')
        tools = tool_input.selectionFilters
        toolBodies = adsk.core.ObjectCollection.create()
        for target in targets:
            targetBody = adsk.fusion.BRepBodies.add(target_input, target)
            for tool in tools:
                toolBody = adsk.fusion.BRepBodies.add(tool_input, tool)
                toolBodies.add(toolBody)
                y = y + 1
        CombineCutInput = root.features.combineFeatures.createInput(targetBody, toolBodies )
        CombineCutFeats = features.combineFeatures
        CombineCutInput = CombineCutFeats.createInput(targetBody, toolBodies)
        CombineCutInput.operation = adsk.fusion.FeatureOperations.CutFeatureOperation
        CombineCutFeats.add(CombineCutInput)
        x = x + 1
        toolBodies.clear()
        targetBody.clear()
    def on_create(self, command, inputs):
        product = _app.activeProduct
        des = adsk.fusion.Design.cast(product)
        # Verify that a Fusion design is active.
        if not des:
            _ui.messageBox('A Fusion design must be active when invoking this command.')
            return()
        command.okButtonText = ("Make the Cuts") # text in "OK" button
        command.isExecutedWhenPreEmpted = False
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = app.activeProduct
        rootComp = design.rootComponent
        sketches = rootComp.sketches
        planes = rootComp.constructionPlanes
        planeInput = planes.createInput()
        # Create the command dialog
        _inputSelectTargets = inputs.addSelectionInput('target', 'Select Target Bodies', 'Select the Bodies\nThat Will Be Cut')
        _inputSelectTargets.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
        _inputSelectTargets.setSelectionLimits(0)
        _inputSelectTools = inputs.addSelectionInput('tool', 'Select Tool Bodies', 'Select the Bodies\nThat Will Do The Cutting')
        _inputSelectTools.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
        _inputSelectTools.setSelectionLimits(0)
        _inputErrMessage = inputs.addTextBoxCommandInput('errMessage', '', '', 2, True)
        _inputErrMessage.isFullWidth = True
Brad Bylls
Tags (2)
1 REPLY 1
brad.bylls
in reply to: brad.bylls
Working it out.
Changed some code.
I verified that target_input =3
I verified that tool_input =2
        target_input = inputs.itemById('target').selectionCount
        tool_input = inputs.itemById('tool').selectionCount
        for x in range (0, target_input):
            target = inputs.itemById('target').selection(x).entity
            toolBodies.clear()
            for y in range (0, tool_input):
                toolBody = inputs.itemById('tool').selection(y).entity
            CombineCutInput = root.features.combineFeatures.createInput(target, toolBodies)
            CombineCutInput = CombineCutFeats.createInput(target, toolBodies)
            CombineCutInput.isKeepToolBodies = True
It runs through the first 'for x in range (0, target_input)' and 'for y in range (0, tool_input) without a problem.
It makes two combine/cuts in the first target. As it should.
But when it gets to 'toolBody = inputs.itemById('tool').selection(y).entity' the second 'x' time, (this is line 41) I get this error message:
As far as I can tell the index is the same as the first time through.
Any help appreciated.
Brad Bylls
Technology Administrators
