Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
combine cut feature problem
1 REPLY 1
brad.bylls
160 Views, 1 Reply
I am having trouble with a combine cut feature.
I have used similar code in other components without problems (simple cut and paste), but this one doesn't work and the exception error tells me nothing to help.
Debugging both codes step by step didn't reveal anything either. Pretty much identical.
A video is attached.
Here is my code in question:
# Create body with combine
    bushingBody = headExt.bodies[0]
    bodyCollection = adsk.core.ObjectCollection.create()
    bodyCollection.add(bushingPFODExt.bodies[0])
    bodyCollection.add(bushingSFODExt.bodies[0])
    model = design.activeComponent
    features = model.features
    combineFeat = features.combineFeatures
    combineInput = combineFeat.createInput(bushingBody, bodyCollection)
    combineFeatur = combineFeat.add(combineInput)
    # Create the ID
    bushingIdSketch = sketches.addWithoutEdges(xyPlane)
    bushingIdCircle = bushingIdSketch.sketchCurves.sketchCircles.addByCenterRadius(center, numBushingID / 2)
    bushingIdSketch.sketchDimensions.addDiameterDimension(bushingIdCircle, adsk.core.Point3D.create(110))
    bushingIdSketch.name = 'I.D. Sketch'
    bushingIdProf = bushingIdSketch.profiles[0]
    bushingIdExtInput = extrudes.createInput(bushingIdProf, adsk.fusion.FeatureOperations.CutFeatureOperation)
    distance4 = adsk.fusion.DistanceExtentDefinition.create(adsk.core.ValueInput.createByReal(numBushingLength))
    distance4A = adsk.fusion.DistanceExtentDefinition.create(adsk.core.ValueInput.createByReal(numBushingLength * -1))
    deg0 = adsk.core.ValueInput.createByString("0 deg")
    bushingIdExtInput.setTwoSidesExtent(distance4, distance4A, deg0, deg0)
    bushingIdExtInput.participantBodies = [combineFeatur.bodies.item(0)]
    bushingIdExt = extrudes.add(bushingIdExtInput)  <<<< line 297 in the exception
    bushingIdExt.name = 'Bushing ID'
Brad Bylls
1 REPLY 1
brad.bylls
in reply to: brad.bylls
Figured it out.
I had to make both distance4 and distance4A positive, even though they were going in opposite directions.
Brad Bylls
