Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Color Effect for Head-Up Display
8 REPLIES 8
Message 1 of 9
nnikbin
252 Views, 8 Replies
Selecting a body in browser shows its name at the bottom-right corner of the viewport. As shown in the following picture, the color of the text changes to make contrast between the text and the set viewport background based on [Settings > Environment]
Similar to it, I want to make a Head-Up Display (HUD) using CustomGraphicText and control its color to make contrast with the viewport background. Unfortunately there is no CustomGraphicsInverColorEffect to automatically change the text color and I was not able to find any API to get the current viewport environment name or color.
It is possible to use a color like green for HUD or to put a solid background layer underneath the text to make some contrast but none of these solutions is ideal.
I appreciate any suggestions to make a HUD which is readable for any selected viewport environment.
8 REPLIES 8
Message 2 of 9
BrianEkins
in reply to: nnikbin
I'm sure there's nothing in the existing API to help with this.  It's a good question though and something that's not been considered before.  It would be interesting to find out how Fusion does this internally.  If it's getting the background color and then setting the color of the text to be contrasting or if there's a more automatic way internally where the text color is set automatically.  I suspect the former, but I don't know.
Brian Ekins
Message 3 of 9
nnikbin
in reply to: BrianEkins
Thank you @BrianEkins  for your informative reply.
Message 4 of 9
JeromeBriot
Try this :
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui  = app.userInterface
        EnvironmentID = app.executeTextCommand('Options.Get EnvironmentIDId').split()[-1]
        ui.messageBox(EnvironmentID)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Returned ID and corresponding RGB values are:
  • DarkSky - [51, 51, 51]
  • GreyRoom - [84, 84, 83]
  • PhotoBooth - [255, 255, 255]
  • TranquilityBlue - [63, 137, 200]
  • InfinityPool - [130, 145, 152]
You can also parse the file NGlobalOptions.xml (C:/Users/<UserName>/AppData/Roaming/Autodesk/Neutron Platform/Options/<UserID>/ on Windows) :
<GraphicsOptionGroup>
  <EnvironmentIDId ToolTip="Eclairage, arrière-plan et divers paramètres de couleur" UserName="Environnement" Value="DarkSky"/>
</GraphicsOptionGroup>
Message 5 of 9
nnikbin
in reply to: JeromeBriot
Wonderful! Thank you @JeromeBriot
I do not know how reliable are these unofficial commands for using in add-ins that will be distributed. I guess for my problem the benefit may be more that the possible risk of breaking in future versions of Fusion 360. What do you think? Do you use them for a similar problem?
Message 6 of 9
JeromeBriot
I try to avoid these unofficial commands. But AFAIK, this is the only solution here. And I think that the environment setting is stable now in Fusion 360.
You could try different methods successively:
  1. Use app.executeTextCommand
  2. Parse the XML file
  3. Ask the user
import xml.etree.ElementTree as etree
import platform
import os
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        try:
            EnvironmentID = app.executeTextCommand('Options.Get EnvironmentIDI').split()[-1]
            EnvironmentIDFound = True
        except:
            EnvironmentIDFound = False
        if not EnvironmentIDFound:
            if platform.system() == 'Windows':
                xmlFile = os.path.join(os.getenv('APPDATA'), 'Autodesk', 'Neutron Platform', 'Options', app.currentUser.userId, 'NGlobalOptions.xml')
            else:
                xmlFile = os.path.join(os.path.expanduser('~'), 'Library', 'Application Support', 'Autodesk', 'Neutron Platform', 'Options', app.currentUser.userId, 'NGlobalOptions.xml')
            if os.path.exists(xmlFile):
                node = etree.parse(xmlFile).getroot().find('GraphicsOptionGroup').find('EnvironmentIDId')
                if node is not None and 'Value' in node.attrib:
                    EnvironmentID = node.attrib['Value']
                else:
                    EnvironmentID = 'PhotoBooth'
            else:
            (EnvironmentID, isCancelled)  = ui.inputBox('Enter the name of the current environment', 'Select environment', 'PhotoBooth')
    except:
        if ui:
Message 7 of 9
nnikbin
Thank you @JeromeBriot  for your good suggestion, and thank you for sharing your opinion on using unofficial text commands.
Message 8 of 9
kandennti
@JeromeBriot  Great job!
It looks like you can get the various folder paths used in Fusion360 with this.
Paths.Get
It's probably OS independent.
import json
def run(context):
    ui = None
    try:
        dirName ='optionsDirectory'
        ui.messageBox(F'-- {dirName} --\n{getEnvironmentFolderPath(dirName)}')
    except:
        if ui:
# --Get environment folder path--
# NameList Fusion360 ver2.0.9937
#     "rootDirectory",
#     "executableDirectory",
#     "localizationDirectory",
#     "coreAddInDirectory",
#     "stringTableDirectory",
#     "appDirectory",
#     "sharedExtensionDirectory",
#     "temporaryDirectory",
#     "unbrandedUserDataDirectory",
#     "userDataDirectory",
#     "allUsersDataDirectory",
#     "unbrandedUserAppPluginsDirectory",
#     "unbrandedAllUserAppPluginsDirectory",
#     "bootstrapOptionDirectory",
#     "optionsDirectory",
#     "cloudCacheDirectory",
#     "isInstalledBuild",
#     "scriptsDirectory",
#     "autorunScriptsDirectory",
#     "samplesScriptsDirectory",
#     "programDataScriptsDirectory",
#     "appDataScriptsDirectory",
#     "manuallyInstalledScriptsDirectory",
#     "materialsDirectory",
#     "testTempDirectory",
#     "scratchDirectory",
#     "resultDirectory",
#     "sampleDirectory",
#     "AppLogFilePath",
#     "CacheDirectory",
#     "autoSaveDirectory",
def getEnvironmentFolderPath(name :str):
    paths = json.loads(app.executeTextCommand(u'Paths.Get'))
    return paths.get(name)
Message 9 of 9
nnikbin
in reply to: kandennti
Thank you @kandennti  for your reply and sharing this information
