Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Code Hint
2 REPLIES 2
John_L_Hermosa
456 Views, 2 Replies
Code Hint
Hi, I'm new in Python...
Is there any way to turn on the code hint in python? or that option do not exist?
Please refer to the attach image.
Thanks in advance
Autodesk Inventor 2015 Certified Professional
Autodesk Factoty Design Suite Ultimate
Tags (1)
2 REPLIES 2
ekinsb
in reply to: John_L_Hermosa
Python does support code hints but in many cases you'll need to do a bit more coding to help the code hint engine understand what your variables represent.  I've added a new section to the "Python Specific Issues" topic in the Fusion API Help for the upcoming update later this month that describes this.  I've gone ahead and taken a snapshot of this new contents (that was the easiest way to get the full content here).  Hopefully this will help.PythonCodeHints.png
Brian Ekins
Mod the Machine blog
John_L_Hermosa
in reply to: ekinsb
Thank you Brian for your answer.
