Announcements
Code for control of the camera
Peter__B
Peter__B
Hi
The code below controls the camera in Fusion 360. The code works properly but there are some additional assignments that I have to do which to my knowledge should not be necessary and should be possible to replace them by just one assignment.
In the code I have to assign (part of the code below):
        cam.eye = adsk.core.Camera.eye
        cam.target = adsk.core.Camera.target
        cam.upVector = adsk.core.Camera.upVector
        cam.isSmoothTransition = adsk.core.Camera.isSmoothTransition
It seems to be necessary to make the assignment property by property in order to get the code working. It would be much easier if I could make the assignment for all properties att the same time by
cam = adsk.core.Camera
but if I try to execute the code with this assignment I get the error code: Is there anybody that can explain what I am doing wrong ?
Error CodeError Code
#Author-
#Description-
import adsk.core, adsk.fusion, traceback, math
app = adsk.core.Application.get()
def run(x):
    try:
        cam = app.activeViewport.camera
        target = adsk.core.Point3D.create(0,0,100)
        up = adsk.core.Vector3D.create(0,0,1)
        eye = adsk.core.Point3D.create(500,500,100)
        steps = 500
        adsk.core.Camera.eye = eye
        adsk.core.Camera.target = target
        adsk.core.Camera.upVector = up
        adsk.core.Camera.isSmoothTransition = False
        app.activeViewport.camera = cam
        ViewDist = adsk.core.Camera.target.distanceTo(adsk.core.Camera.eye)
        for i in range(0, 2*steps):
            eye = adsk.core.Point3D.create(2*ViewDist * math.cos((math.pi*2) * (i/steps)),\
            ViewDist * math.sin((math.pi*2) * (i/steps)), 100)
            cam.eye = eye
            adsk.doEvents()
            app.activeViewport.refresh()
    except:
        ui = app.userInterface
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Best Regards
Peter
marshaltu
I simplify your codes as below. "cam = app.activeViewport.camera" just gets a (temporary)copy of current camera. You can edit its parameters and set it back to active viewport to make the changes take effect.
Marshal
import adsk.core, adsk.fusion, adsk.cam, math, traceback
def run(context):
    ui = None
    try:
        steps = 500
        cam.eye = eye
        cam.target = target
        cam.upVector = up
        cam.isSmoothTransition = False
        ViewDist = target.distanceTo(eye)
            cam.eye = eye
            adsk.doEvents()
    except:
        if ui:
Marshal Tu
Fusion Developer
Peter__B
Thanks Marshal
I also did that myself (copying a the current camera), but why do I get an error when I try to make the assignment ?
If I make the assignments it property by property i.e.  cam.eye = adska.core.Camera.eye  etc. it works.
Is the assignment, cam = adsk.core.Camera, not allowed ?
/Peter
marshaltu
"adsk.core.Camera" is an API object. We didn't provide assignment operator for it.
Marshal
Marshal Tu
Fusion Developer
MichaelT_123
Hi, Mr.Peter  and Mr.Tu
'adsk.core.Camera' is a type of gibberish most programmers commit quite often.
Just correct it a little bit to:  'adsk.core.Application.get().activeViewport.camera' and you will be on a solid path for ... for the next one 🙂
Regards
MichaelT_123
MichaelT
