Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Class Object
3 REPLIES 3
Peter__B
336 Views, 3 Replies
Class Object
Hello
Part of my python code contains the following:
class ParameterChange:
      def __init__(self,dia, length):
           self.DIA = dia
           self.LENGTH = length
If I execute it and also run e.g.
param = ParameterChange(1.1,2.2), I will get for param.DIA...1.1 but python says that param.LENGTH does not exist. Just the first works.
In standard python it works but not in the Spyder version in fusion 360.
Does anybody know why ?
Best Regards
Peter
3 REPLIES 3
JeromeBriot
in reply to: Peter__B
the following script works as expected:
import adsk.core, traceback
           self.DIA = dia
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        ui.messageBox('{} , {}'.format(param.DIA, param.LENGTH))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Peter__B
Is it necessary to have all statements e.g. in the run function ? or can I have them outside to ? perhaps it special for "python Spyder fusion script" ?
/Peter
ross.korsky
In short, no. You can write your code outside the "run" method but you need to hook into "events" to do so - see this help topic.
I write my add-ins like proper python with objects, modules, packages, the whole bit. See this post for my boiler plate code which uses some black magic to abstract away the irritating "event object instance" pains.
