I trying to pick a material stored in my 'Favorites' and assign to a body but get the error shown in the pic.
I've used the following code, and worked fine when picking from the 'Fusion 360 Material Library'
# get material lib
mLibs = app.materialLibraries
mLib = mLibs.itemByName('Favorites')
# get one material from this lib
mOne = mLib.materials.itemByName('AB2')
BladeLoftBody = BladeLoft.bodies.item(0)
bodyM = BladeLoftBody.material
# change body material
BladeLoftBody.material = mOne
app.activeViewport.refresh()
Many Thanks in advance.
Solved by JeromeBriot. Go to Solution.
the error message says that the object mLib is empty (None). You should always test the returned value when accessing an item of a collections. For example:
import adsk.core, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface materialLibrary = 'Favorite' mLibs = app.materialLibraries mLib = mLibs.itemByName(materialLibrary) if mLib is None: ui.messageBox('Material "{}" not found.'.format(materialLibrary)) return except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
To solve your problem, replace:
with:
mLib = mLibs.itemByName('Favorites Library')
Here is a code to list all material libraries by name:
import adsk.core, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface mLibs = app.materialLibraries for mLib in mLibs: print(mLib.name) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
You can use the same approach with any collections when you need to get a specific item by name.
Hope this helps
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Fantastic thanks for the help, its working perfectly now.
Just starting out in the API area so will no doupt have many more questions.
