Check if data panel is opening
j.han97
j.han97
Hi all,
This might be an easy question but I cannot find the right function to achieve my objective. In short, I want to know if the data panel on the side is active (opened/showed). If true, it will be closed.
I am able to close it using respective command definitions. The part I'm struggling with is the API to check the states of the data panel.
Thank you all!
j.han97
Ok, I actually found the corresponding function right after I posted this. For others who are searching for this as well:
app = adsk.core.Application.get()
app.data.isDataPanelVisible # <-- Returns boolean that indicates the state of data panel
