Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Changing Camera View from Perspective to Orthographic Using API?
2 REPLIES 2
knightsAHN63
212 Views, 2 Replies
Hello all! Has anyone written any scripts or add-ins that change the camera view type? We are developing an add-in and hoping to automatically change our user's view to ensure that it is only 'Orthographic' instead of defaulting to perspective. Any advice is greatly appreciated! Attached is quick screenshot of what we are hoping to do with API.
2 REPLIES 2
kandennti
in reply to: knightsAHN63
Hi @knightsAHN63 .
You can switch between them using the Camera.cameraType property.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-c1d597b4-69c2-4b91-ab39-659f23f7f61d
The camera is retrieved from the Viewport.camera property, but be aware that you need to reassign it to get a copy.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2005e69c-36cd-45a2-bb3d-8cf5b968ab9a
The zoom position is quite different from when the cameraType is switched in the GUI.
I've used it here. I couldn't figure out the formula.
https://github.com/kantoku-code/Fusion360_PerspectiveAngleController
knightsAHN63
in reply to: kandennti
Thank you so much, got it working! Appreciate your help.
