Changing addon icons not working
Joshua.mursic
Joshua.mursic
Hello, I am trying to update the icon of a button in my addon. But when i set the .resourceFolder property, the icon does not update. If I reset the panel customization, the icon updates, or if I remove it from the panel and then put it back, it will also update. Am I missing something?
import adsk.core,os
from ...lib import fusion360utils as futil
app = adsk.core.Application.get()
ui = app.userInterface
filePath = os.path.join(os.path.dirname(os.path.abspath(__file__)))
iconPath1 = os.path.join(filePath,"icon1")
iconPath2 = os.path.join(filePath,"icon2")
buttonFunction = 1
def command_created(args: adsk.core.CommandCreatedEventArgs):
    if buttonFunction == 1:
        args.command.parentCommandDefinition.resourceFolder = iconPath2
        futil.add_handler(args.command.execute, command_1)
        futil.add_handler(args.command.destroy, command_destroy)
    else:
        args.command.parentCommandDefinition.resourceFolder = iconPath1
        futil.add_handler(args.command.execute, command_2)
def command_1(args: adsk.core.CommandEventArgs):
    app.log("switching to icon 2")
    app.log(f"{iconPath2}")
def command_2(args: adsk.core.CommandEventArgs):
    app.log("switching to icon 1")
    app.log(f"{iconPath1}")
def command_destroy(args: adsk.core.CommandEventArgs):
    global buttonFunction
        buttonFunction = 2
    else:
        buttonFunction = 1
john.kirchner
This issue should be fixed in the current Insider build/the next Fusion release, which will be later this month.
One workaround is related to what you observed - force an update of the icon through a different function. So you can add this line after setting the resourceFolder and it should work:
args.command.parentCommandDefinition.name = args.command.parentCommandDefinition.name
Joshua.mursic
Fantastic, thank you for the workaround
