10:43 AM
Hi, How do I change units using the API?
I've very simplistically tried this:
global _app, _ui, _design
_app = adsk.core.Application.get()
_ui = _app.userInterface
product = _app.activeProduct
_design = adsk.fusion.Design.cast(product)
_design.unitsManager.defaultLengthUnits = 'm'based on your documentation (which I also can't link here, another problem I should probably create a forum post about at some point...) Anyway it was from:
As the document says:
"Returns a specialized UnitsManager that can set the default length units and work with parameters.
Defined in namespace "adsk.fusion" and the header file is "adsk/fusion/Fusion/Design.h"."
But then you read underneath:
Property Value
This is a read only property whose value is a FusionUnitsManager."
So read only... How can I set it then?
