Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Change the flip parameter
3 REPLIES 3
l.diana9
256 Views, 3 Replies
Hello!
jnt :adsk.fusion.Joint = components.itemByName('MUVPAssemby').joints.itemByName('Rigid2')
offset :adsk.fusion.ModelParameter = jnt.offset
offset.expression = str(-int(hSp[:-3]))
app.activeViewport.refresh()
Here's a part of my code I have changed the parameter of offset. And I wanted to ask you If you know hot to change the Flip parameter just the same way?
Labels (2)
3 REPLIES 3
BrianEkins
in reply to: l.diana9
The Joint object supports the isFlipped property.  It's a read-write property so you can get and set the flipped state.  The line below can be added to yours to flip the direction.
jnt.isFlipped = not jnt.isFlipped
Brian Ekins
kandennti
in reply to: BrianEkins
@BrianEkins .
When I tried using Fusion360 Ver. 2.0.10253, it gave me errors in all cases.
    jnt.isFlipped = True
    jnt.isFlipped = False
@l.diana9 .
You should be able to get to your goal faster if you ask your question in the forum rather than in a private message.
BrianEkins
in reply to: kandennti
Most edits to a joint require the timeline to be rolled to before the joint.  Here's a snippet that demonstrates the workflow by flipping a selected joint.
# Get a joint by having the user select one.
joint: adsk.fusion.Joint = ui.selectEntity('Select a joint.', 'Joints').entity
# Get the current position of the marker in the timeline.
tlPstn = des.timeline.markerPosition
# Reposition the marker to before the joint.
joint.timelineObject.rollTo(True)
# Change the isFlipped property.
joint.isFlipped = not joint.isFlipped
# Reposition the timeline marker to the original position.
des.timeline.markerPosition = tlPstn
Brian Ekins
