Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Change the 'caption' of an IntegerSliderCommandInput
2 REPLIES 2
MarkBrouwersY48AV
131 Views, 2 Replies
I want to change the caption of an IntegerSliderCommandInput
I want to add the name of the selected value in my combobox to my IntegerSliderCommandInput text.
So in this case I would like to see 'Selected Parameter value Diameter'.
I tried the function IntegerSliderCommandInput.settext, but this does not work. Changing the name property of this IntegerSliderCommandInput is not allowed.
How can this be done ?
Cheers,
Mark
2 REPLIES 2
Hi @MarkBrouwersY48AV -San.
Perhaps that is not possible.
It seems that the events of the Command object have a role to play, not simply a different timing when they occur.
It seems that it is only within the commandCreated event handler that the name property of IntegerSliderCommandInput can be changed, as in this case.
As an alternative, I created a sample.
The only way to do this is to prepare the IntegerSliderCommandInput corresponding to the ComboBox (DropDownCommandInput) in advance and show/hide it.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    'id': 'kantoku_test',
    'name': 'test',
    'tooltip': 'test'
_dDownIpt: core.DropDownCommandInput = None
_sliderA: core.IntegerSliderCommandInput = None
_sliderB: core.IntegerSliderCommandInput = None
_sliderC: core.IntegerSliderCommandInput = None
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onInputChanged = MyInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            global _dDownIpt
            _dDownIpt = inputs.addDropDownCommandInput(
                "_dDownIptId",
                "Choice",
                core.DropDownStyles.TextListDropDownStyle
            dDownItems: core.ListItems = _dDownIpt.listItems
            dDownItems.add("A", True)
            dDownItems.add("B", False)
            dDownItems.add("C", False)
            global _sliderA
            _sliderA = inputs.addIntegerSliderCommandInput(
                "_sliderAid",
                "A",
                0,
                10,
            global _sliderB
            _sliderB = inputs.addIntegerSliderCommandInput(
                "_sliderBid",
                "B",
                0,
                10,
            _sliderB.isVisible = False
            global _sliderC
            _sliderC = inputs.addIntegerSliderCommandInput(
                "_sliderCid",
                "C",
                0,
                10,
            _sliderC.isVisible = False
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.InputChangedEventArgs):
        global _dDownIpt
        if args.input != _dDownIpt: return
        global _sliderA, _sliderB, _sliderC
        selectName = _dDownIpt.selectedItem.name
        if selectName == "A":
            _sliderA.isVisible = True
            _sliderB.isVisible = _sliderC.isVisible = False
        elif selectName == "B":
            _sliderB.isVisible = True
            _sliderA.isVisible = _sliderC.isVisible = False
        elif selectName == "C":
            _sliderC.isVisible = True
            _sliderA.isVisible = _sliderB.isVisible = False
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
If you want to create more flexible dialogs, we recommend using Palette or BrowserCommandInputs.
However, knowledge of html and javascript is required.
Hi Makoto,
Thanks again for your reply and suggesting a solution.  understand what you're doing and this works for me to some extend.
Kudo's for you !
Cheers,
Mark
