Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Change CAM-Setup-Parameter via API (raw part - height)
2 REPLIES 2
blue983
350 Views, 2 Replies
Hi there,
is there any possibility to change the CAM-Setup-Parameters (in this case the height of the raw part - see the yellow marking in the screenshot)?
Thanks!
Kind regards,
Steven
2 REPLIES 2
kandennti
in reply to: blue983
Hi @blue983 .
As far as you can see in the help setup object, you can't change the value.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-960B1B56-1D05-4517-9663-8C19B21E31B3
It is possible to get the value by using postProcess, but I think it is impossible to change it.
blue983
in reply to: kandennti
Hi kanndenti,
thanks for your response. I found the following solution:
Using a parametric volume as raw-part-borders makes me able to manipulate the raw-part-size via the api. That's what i need 🙂
Kind regards, Steven
