Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Cannot save project after running script
6 REPLIES 6
Joshua.mursic
344 Views, 6 Replies
I have a script that runs well and completes without issue. However, when I go to save the project I get the following error:
Error: The source asset Toolpath in document Untitled v1 has not referenced the target asset FusionAssetName in document Untitled v1!
I went through my script and commented out the sections until I found what is causing the issue, but I don't know how to change it to fix the save problem.
I am using some tricks that I saw @kandennti  explaining in this thread:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/create-new-cam-setups/m-p/10215806
as well as some others from other posts.
I think that the TextCommand UI.EnableCommandInput is causing issues.
# Select Z Axis for setup
zAxis = design.rootComponent.zConstructionAxis
app.executeTextCommand(u'UI.EnableCommandInput job_rotaryAxis')
sels.clear()
sels.add(zAxis)
Thanks in advance for any assistance,
Kind regards,
Josh
6 REPLIES 6
kandennti
in reply to: Joshua.mursic
Hi @Joshua.mursic .
I was able to reproduce the phenomenon of not being able to save, but I don't know how to work around it.
Joshua.mursic
in reply to: kandennti
Thank for taking the time to check this out.
A solution that you provided me to this question:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/activate-a-folder-in-the-cam-environment/t...
has given me another method to achieve what I am trying to do so I am not going to use this method. Thanks.
EDIT: My work around method is not working, very well. I would like to try and find a solution to this problem still.
Joshua.mursic
I think that I found the issue,
This is referring to anitem in the design environment not the manufacturing environment. which I believe is causing the issue.
I am using the methods you describe to select objects using ONK, however, I am having issues.
I am now trying to select this object in the browser tree using ONK.
This is the script that I am using to target it:
zAxisONK = u'ONK::CmpInst={}/Cmp={}/CmpInsts/CmpInst={}%3A1/Cmp={}/CmpInsts/CmpInst={}/Cmp={}/{}/{}/LeafType:16777216=0'.format(
    quote(app.activeDocument.name),
    quote('CAM Component'),
    quote(cam.designRootOccurrence.name),
    quote('OriginWorkGeometry'),
    quote('WorkAxis=Z'))
app.log(zAxisONK)
zAxisSelect = app.executeTextCommand(u'Commands.Select {}'.format(zAxisONK))
app.executeTextCommand(f'UI.EnableCommandInput job_rotaryAxis')
ui.activeSelections.add(zAxisSelect)
However I am getting this error:
RuntimeError: 3 : Invalid object path.
my script is returning this as the ONK:
ONK::CmpInst=TEST%20v0/Cmp=TEST%20v0/CmpInsts/CmpInst=CAM%20Component%3A1/Cmp=CAM%20Component/CmpInsts/CmpInst=TEST%20v0%3A1/Cmp=TEST%20v0%3A1/OriginWorkGeometry/WorkAxis%3DZ/LeafType:16777216=0
But when I use your Developers Small tool kit addon and get the ONK with this button
It get this ONK:
ONK::CmpInst=TEST%20v0/Cmp=TEST%20v0/CmpInsts/CmpInst=CAM%20Component%3A1/Cmp=CAM%20Component/CmpInsts/CmpInst=TEST%20v2%3A1/Cmp=TEST%20v2/OriginWorkGeometry/WorkAxis=Z/LeafType:16777216=0
I think that the  'cam.designRootOccurrence.name' is getting the name before the document is fully saved, and is returning the wrong version number. But this is only a guess.
Is there a way to wait for the document to finish saving before continuing the code?
kandennti
@Joshua.mursic .
Due to my busy schedule, I have not been able to confirm anything.
It is certainly likely that CAD elements are treated differently in design than in manufacture.
kandennti
@Joshua.mursic .
Do not get "ONK" in the design state, but get "ONK" in the manufacture state.
It is faster to run a text command directly before running it in a script to check its operation.
For people looking for answers to this bug, I think that I found the problem. If you target an individual mesh body to be used for machining, this error occurs, but if you instead put that mesh inside a new component and then target the entire component, this error does not seem to appear.
