Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Cannot Load Addins
4 REPLIES 4
libertydocservice
1582 Views, 4 Replies
Cannot Load Addins
Please view the attached photo to see error messages. This happens on startup, and I am not sure if it is affecting performance in CAD. The errors seem to be associated with CAM.
Tags (1)
4 REPLIES 4
Phil.E
in reply to: libertydocservice
Sorry for the trouble.
This is a known issue associated with the new UI preview. Do you have that turned ON? Check Preferences > Preview and look for the item "UI Preview". Un-check that box, if it's checked, and restart Fusion.
If it's not that, I will escalate this to product support.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
libertydocservice
in reply to: Phil.E
Thanks for your response. That box was NOT checked, and the problem
persists.
Hi @libertydocservice
Thanks for posting! This error message is usually related to an installation or update error rather than the add-ins it references. Please perform a clean uninstall and reinstall Fusion 360 - this should eliminate the error.
In my experience, this warning is purely cosmetic and does not seem to effect the normal operation of Fusion 360. Please let me know if you see any behavioral problems - I am happy to continue troubleshooting.
Paul Clauss
Product Support Specialist
Thank you for your reply and solution.
I did have to delete a file called "webdeploy" first because something else was missing.
The program now starts up clean and fast.
Thanks again,
Happy Modeling...
