Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Cannot Attach Xcode to Fusion
7 REPLIES 7
Message 1 of 8
neil.mendoza
898 Views, 7 Replies
API support seems super buggy. I switched to using C++ because Python editing is broken, followed these instructions for debugging...
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ECC0A398-4D89-4776-A054-F7B432F7FCF6
...and get the following error when I try to attach Xcode to Fusion 360...
Details
Could not attach to pid : “1626”
Domain: IDEDebugSessionErrorDomain
Code: 3
Failure Reason: Error 1
Error 1
Code: 3
7 REPLIES 7
Message 2 of 8
Mattxer
in reply to: neil.mendoza
May i ask what was broken with python? were you using it with vscode? If so there is a known issue that has a simple workaround.
See this thread > https://forums.autodesk.com/t5/fusion-360-api-and-scripts/not-able-to-debug-scripts-add-ins-in-visua...
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
Message 3 of 8
neil.mendoza
in reply to: Mattxer
Thanks, I actually gave up on Python and wrote it in C++ debugging with a log file. Will try Python again next time I need to script something.
Message 4 of 8
I have the same problem, porting our add-in from windows to Mac and can't debug. Is there still no solution to this?
Could not attach to pid : “1935”
Code: 3
User Info: {
    DVTRadarComponentKey = 855031;
    RawLLDBErrorMessage = "Error 1";
Message 5 of 8
nnikbin
in reply to: rolandas.vegis
Hi  @neil.mendoza , @rolandas.vegis , @Mattxer
I had the same problem with debugging my add-in on macOS Catalina (running on VirtualBox). Turning off SIP (or System Integrity Protection) solved it.
You should be very careful about disabling SIP, because it is one of the primary mechanisms which macOS uses to protect itself (it is introduced in El Capitan-2015). So remember to re-enable SIP when you've finished your task.
Message 6 of 8
KrisKaplan
Is it possible that you don't have developer mode enabled? You can try running the following in a terminal:
sudo DevToolsSecurity -enable
Shot in the dark...
Kris
Kris Kaplan
Message 7 of 8
nnikbin
in reply to: KrisKaplan
Hi @KrisKaplan
Before turning off SIP I googled and found "sudo DevToolsSecurity -enable" and tried it. But in my case it did not work.
I also tried many other suggestions. Only after turning off SIP, Xcode was able to attach to Fusion 360 process. My macOS is running on VirtualBox. Perhaps for other cases enabling DevToolsSecurity will work.
Message 8 of 8
rolandas.vegis
in reply to: nnikbin
Had developer mode enabled, didn't do anything. Disabling SIP, does indeed work, thanks.
