Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Can you use fusion 360 without a separate GPU.
1 REPLY 1
169 Views, 1 Reply
My computer does not have a separate GPU, but I want to use Fusion360 to extract the part information from the .smt file, is that possible?
1 REPLY 1
BrianEkins
in reply to: 17671612454
Here's the page that lists the minimum system requirements to run Fusion. Fusion needs to be running to use the API, so these requirements apply. You can see that you can use Fusion with an integrated graphics card as long as it has at least 6GB of memory.
Brian Ekins
