Hello!
I've been trying unsuccessfully to figure out how to use the import just points and not have it automatically create a spline. Is there a way to accomplish this?
Here's the original python script:
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Get all components in the active design.
product = app.activeProduct
design = product
title = 'Import Spline csv'
if not design:
ui.messageBox('No active Fusion design', title)
return
dlg = ui.createFileDialog()
dlg.title = 'Open CSV File'
dlg.filter = 'Comma Separated Values (*.csv);;All Files (*.*)'
if dlg.showOpen() != adsk.core.DialogResults.DialogOK :
return
filename = dlg.filename
f = open(filename, 'r')
points = adsk.core.ObjectCollection.create()
line = f.readline()
data = []
while line:
pntStrArr = line.split(',')
for pntStr in pntStrArr:
data.append( float(pntStr))
if len(data) >= 3 :
point = adsk.core.Point3D.create(data[0], data[1], data[2])
points.add(point)
line = f.readline()
data.clear()
f.close()
root = design.rootComponent;
sketch = root.sketches.add(root.xYConstructionPlane);
sketch.sketchCurves.sketchFittedSplines.add(points);
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thanks!
Mike
Autodesk Fusion 360 Evangelist
