Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Can't create a pattern on path feature using the Fusion 360 API
2 REPLIES 2
bevis.hobbs21
210 Views, 2 Replies
I am unable to create a pattern on a path feature using the Fusion 360 API.
I ask the user to select a component and multiple paths to pattern that component along. I then loop over those paths and create a pattern on path feature for each path, using the same component every time. But when I do that it comes up with an error.
This is my code:
import adsk.core, adsk.fusion, adsk.cam, traceback
handlers = []
app = adsk.core.Application.get()
if app:
    ui = app.userInterface
class PatternMultipPathsCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            command = args.firingEvent.sender
            component = command.commandInputs.itemById("component").selection(0).entity
            paths_selection = command.commandInputs.itemById("paths")
            paths = [paths_selection.selection(i).entity for i in range(paths_selection.selectionCount)]
            product = app.activeProduct
            design = adsk.fusion.Design.cast(product)
            rootComp = design.rootComponent
            features = rootComp.features
            inputEntites = adsk.core.ObjectCollection.create()
            inputEntites.add(component)
            for item in paths:
                path = features.createPath(item)
                quantity = adsk.core.ValueInput.createByString('3')
                distance = adsk.core.ValueInput.createByString('1 cm')
                pathPatterns = features.pathPatternFeatures
                pathPatternInput = pathPatterns.createInput(inputEntites, path, quantity, distance,
                                                            adsk.fusion.PatternDistanceType.SpacingPatternDistanceType)
                pathFeature = pathPatterns.add(pathPatternInput)
        except:
            if ui:
                ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class PatternMultipPathsCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try: adsk.terminate()
        except:
            if ui:
class PatternMultipPathsInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            cmdInput = eventArgs.input
            if cmdInput.id == "component":
                command.commandInputs.itemById("paths").hasFocus = True
        except:
            if ui:
class PatternMultipPathsCommandCreated(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            cmd.setDialogInitialSize(300, 150)
            onExecute = PatternMultipPathsCommandExecuteHandler()
            cmd.execute.add(onExecute); handlers.append(onExecute)
            onDestroy = PatternMultipPathsCommandDestroyHandler()
            cmd.destroy.add(onDestroy); handlers.append(onDestroy)
            onInputChanged = PatternMultipPathsInputChangedHandler()
            cmd.inputChanged.add(onInputChanged); handlers.append(onInputChanged)
            inputs = cmd.commandInputs
            i1 = inputs.addSelectionInput("component", "Component",
                                          (" " * 3)+"Select a component to be patterned.")
            i1.setSelectionLimits(1, 1); i1.addSelectionFilter("Bodies")
            i2 = inputs.addSelectionInput("paths", "Paths",
                                          (" " * 3)+"Select paths to pattern a component along.")
            i2.setSelectionLimits(1); i2.addSelectionFilter("Edges")
        except:
            if ui:
def run(context):
    try:
        commandDefinitions = ui.commandDefinitions
        # check the command exists or not
        cmdDef = commandDefinitions.itemById("PatternMultipPaths")
        if not cmdDef:
            cmdDef = commandDefinitions.addButtonDefinition("PatternMultipPaths",
                                                            "Pattern Along Multiple Paths",
                                                            "Do a component pattern along multiple paths.")
        onCommandCreated = PatternMultipPathsCommandCreated()
        cmdDef.commandCreated.add(onCommandCreated)
        handlers.append(onCommandCreated)
        inputs = adsk.core.NamedValues.create()
        cmdDef.execute(inputs)
        adsk.autoTerminate(False)
    except:
        if ui: ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
And this is the error I get:
Traceback (most recent call last):
  File "C:/Users/Bevis Hobbs/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Pattern along multiple paths/Pattern along multiple paths.py", line 37, in notify
  File "C:/Users/Bevis Hobbs/AppData/Local/Autodesk/webdeploy/production/eba7fbfbb17ff9a9d7c25530f6f766b5ffb15678/Api/Python/packages\adsk\fusion.py", line 27228, in add
    return _fusion.PathPatternFeatures_add(self, input)
RuntimeError: 5 : Some input argument is invalid.
Labels (1)
2 REPLIES 2
kandennti
in reply to: bevis.hobbs21
Hi @bevis.hobbs21 .
I tried it and did not get any errors.
What kind of data do I need to try to get an error?
bevis.hobbs21
in reply to: kandennti
Not sure if it's a bug in Fusion 360 but the component I was selecting is a derived component and when I broke the link on the derived component the script worked perfectly.
