Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Can I pull the project name and subsequent folder names from the API?
3 REPLIES 3
Chak257
141 Views, 3 Replies
Using python?
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.activeDocument
        partName = doc.name
        print(partName)
This gives me the part name that I am currently working on.   I am looking for a way to pull the name of the parent folder its stored in, as well as any parent folders up to the main project folder it resides in.
Project Folder Name
--Sub Folder Name
----Sub Folder Name 2
------Sub Folder Name 3
--------Part File Name    ( I can get this, but is there a way to pull the names of all the folders above the part level to store in variables? )
3 REPLIES 3
jsormaz
in reply to: Chak257
Start here:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-54a08742-92b2-4831-b9e6-4161b89f6e1e
doc.dataFile.parentFolder.name
you can keep going deeper (.parentFolder.parentFolder) until you get null
Instagram:
@sonsofsormaz
JeromeBriot
Chak257
in reply to: jsormaz
Amazing... I would have never figured this out on my own.. Much appreciation!!!
