Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Camera type bug
3 REPLIES 3
rolandas.vegis
153 Views, 3 Replies
Camera type bug
I noticed a bug with Fusion returning wrong camera type when camera is set to PerspectiveWithOrthoFacesCameraType it returns PerspectiveCameraType.
Demo code used in the video:
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <CAM/CAMAll.h>
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
extern "C" XI_EXPORT bool run(const char* context)
	app = Application::get();
	if (!app)
		return false;
	const auto cameraType = app->activeViewport()->camera()->cameraType();
	auto type = "";
	switch(cameraType)
	case OrthographicCameraType:
		type = "OrthographicCameraType";
		break;
	case PerspectiveCameraType:
		type = "PerspectiveCameraType";
		break;
	case PerspectiveWithOrthoFacesCameraType:
		type = "PerspectiveWithOrthoFacesCameraType";
		break;
	app->userInterface()->messageBox(type, type);
	return true;
3 REPLIES 3
kandennti
in reply to: rolandas.vegis
Hi @rolandas.vegis .
I have experienced this before when I developed this add-in.
https://github.com/kantoku-code/Fusion360_PerspectiveAngleController
Wouldn't PerspektiveWithOrthoFacesCameraType return an OrthographicCameraType if the camera is parallel to the XY, YZ, or XZ plane?
rolandas.vegis
in reply to: kandennti
Yes it does return OrthographicCameraType when camera is parallel to the XY, YZ, or XZ plane. Is this also a bug or is this expected behavior?
kandennti
@rolandas.vegis .
I cannot determine if it is a bug or not.
However, it may be a bug since you even provide an enumerator.
