Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
CAM Postprocessor not working
6 REPLIES 6
tomas.wilhelmsson
380 Views, 6 Replies
Hmm noticed after the last update that my addin for post processing started to fail .. CAM Object -> postProcess fails each time 😕
Do not know how to extract error messages from it 😕
Adding a small example program .. incase ive done something wrong but this one also fails on me 😕
Best regards
/ Tomas
6 REPLIES 6
Thank you for reporting the issue to us. CAM-8729 has been logged to track the issue in our internal system.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Adding diagnosticlogs also here.
Is there any way to follow these issues?
Unfortunately no, I will contact the owner of the bug and see if we can update you the status once the progress is made.
Marshal
Marshal Tu
Autodesk, Inc.
jeff.pek
in reply to: marshaltu
Hi -
Sorry for the inconvenience. This API was unfortunately broken in a recent update.
A fix has been made, and will be released as part of a Fusion update tomorrow evening (26 October).
Jeff
Hey, this issue does not seem to be resolved yet, any update on it?
Best regards / Tomas
Sorry, the update that fixes the issue has been pushed back a few days. It should be released tomorrow (Monday).
  Jeff
