Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
CAM.getMachiningTime
2 REPLIES 2
sukamirko
255 Views, 2 Replies
Hi
I have a bug with script when I call         cam_var.getMachiningTime(all_stuff).machiningTime
I got a very strange result .
Example :
If I call standard machining time in UI for a setup I got 0:02:16
the same call via script with same machine  settings also I converted mm/min to cm/s I got 58 seconds
If I call standard machining time in UI for operation(0) I got 0:00:11
same call via script with same machine settings I got 5 seconds
if I call operation one by one with a script I got for all machining time 5 seconds
With UI Operations one by one I got  0:00:11
        0:00:20
        0:00:21
        0:00:56 etc...
Something is strange 🙂
2 REPLIES 2
BrianEkins
in reply to: sukamirko
I just ran a little test with a file of mine and am getting the same results as I see in the UI.  One thing that isn't clear from the documentation and is something I had to fix from my initial test is the Feed scale percentage.  What works is a value between 0 and 1.  1 is the same as 100%.  You said you already did it, but I did have to convert the rapid speed to centimeters/sec.  Once I had those two things correct, the numbers I got from the API match what I see in the UI.
Brian Ekins
sukamirko
in reply to: BrianEkins
Thanks for your help
This is where is my code wrong feed scale is 0-1
I did not even think that this is a problem Thank you
