Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
CAM api to get toolpath data?
3 REPLIES 3
gina68ABR
152 Views, 3 Replies
I would like to figure out the minimum z for an operation. Is there a way to get this from the api? Perhaps I can get at the toolpath data somehow?
3 REPLIES 3
Jorge_Jaramillo
in reply to: gina68ABR
I was checking the Operation.generatedDataCollection property for some operations but it looks empty in my models.
As an alternative solution, I'd suggest you to run the postprocessor for the operation you need and then look in the output file for the minimum Z value.
There is an example to run the postprocessor here: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-BF31EB56-B612-44C8-8F07-0C183036C803
Jorge Jaramillo
Software Engineer
gina68ABR
in reply to: Jorge_Jaramillo
I might get desperate enough to use the post processing option, thank you
Jorge_Jaramillo
Please find attached a short script to discover max's and min's of every axis in a post file:
import re
import os
def discover_max_min(filename: str) -> dict:
    reg_exprs = {}
    results = {}
    for key in ['X', 'Y', 'Z']:
        reg_exprs[key] = re.compile(f"{key}([0-9\-\.]+)", re.IGNORECASE)
        results[key] = {'min': float('inf'), 'max': float('-inf')}
    with open(filename, 'r') as tap_file:
        for line in tap_file:
            if line[0] != '(':  # comment lines start with '('; skip them
                for k in results.keys():
                    for m in re.findall(reg_exprs[k], line):
                        try:
                            val = float(m)
                            if val < results[k]['min']:
                                results[k]['min'] = val
                            elif val > results[k]['max']:
                                results[k]['max'] = val
                        except:
                            pass  # ignore any string to float conversion error
    return(results)
if __name__ == "__main__":
    filename = os.path.join("/","CNC","TAPs","test_file.tap")  # set path according to your directory structure
    print(f'{discover_max_min(filename)}')
I hope this can help you out.
Jorge Jaramillo
Software Engineer
