Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Bugs in IntegerSpinnerInput
1 REPLY 1
erik
285 Views, 1 Reply
I found a couple of bugs in the IntegerSpinnerCommandInput:
First, I tried to change the maximumvalue after I used the contructor. This resulted in no change in the maximumvalue when I tested the code.
Then I wondered if I could just leave out the rest code in the constructor and not provide it with a maximum value but that wasn't an option.
The reason I found this bug was because I wanted to have a spinner without a maximum value, but I was unable to achieve that as well.
The second issue I found might not be on purpose. The spinner will change the value to 1 below the previous valid value, when the user has entered a value above the maximum value and use the arrow down. Is there a reason for not going to the maximum value? That seems more intuitive to me.
The third one is not a bug, but if anyone have an explanation as to why one cannot raise the value with each mouse click if one click too fast. It is by no means a problem I just wondered why.
- Erik
1 REPLY 1
zhongyang.chenK3XZJ
in reply to: erik
Thanks for reporting these bugs.
For the first issue, the maximumvalue is a readonly property. Currently the value range of a spinner command input cannot be modified after creation.
For the second issue, I think it is an Fusion UI behavior, not an API issue. You can post your what you want at Fusion 360 IdeaStation here: https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125/tab/most-recent
Fusion may change current behavior in the future if most people like this idea.
For the third issue, I don't have a good explanation now. Hopefully someone else may know more about it.
Zhongyang Chen
Fusion 360 API Developer
Technology Administrators
