Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Bug? UserInterface.selectEntity should return None but fails
4 REPLIES 4
JeromeBriot
263 Views, 4 Replies
According to the documentation, the UserInterface.selectEntity method returns None if the selection is aborted.
I guess that the selection is aborted by pressing the Esc key. But in that case, the method returns an error message:
Here is a code to reproduce the issue:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        # Draw some circles.
        circles = sketch.sketchCurves.sketchCircles
        circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 2)
        circle2 = circles.addByCenterRadius(adsk.core.Point3D.create(8, 3, 0), 3)
        # Add a circle at the center of one of the existing circles.
        circle3 = circles.addByCenterRadius(circle2.centerSketchPoint, 4)
        selection = ui.selectEntity('Select a profile', 'Profiles')
        if not selection:
            ui.messageBox('No profile selected')
        else:
            ui.messageBox('One profile selected')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thanks.
4 REPLIES 4
dinocoglitore
in reply to: JeromeBriot
I found the same problem with the selection of a Body.
bodySel = ui.selectEntity('Select a body''Bodies')
        if bodySel:
            body = adsk.fusion.BRepBody.cast(bodySel.entity)
        elif bodySel == None:
            ui.messageBox("Selection not correct")
            exit
If I look at the bodySel variable inside Debug Console this is the answer:
Dino
kandennti
Hi .
This has been happening for a long time.
I always respond using try-except.
        selection = selectEnt(ui, 'Select a profile', 'Profiles')
        if selection is None:
        else:
    except:
        if ui:
def selectEnt(ui, msg, filtter_str):
    try:
        selection = ui.selectEntity(msg, filtter_str)
        return selection
    except:
        return None
JeromeBriot
in reply to: kandennti
Thank you@kandennti
This workaround works perfectly!
dinocoglitore
Thanks a lot.
Dino
