Announcements
Bug? Unable to delete a button promoted to a panel when its parent is a dropdown
JeromeBriot
JeromeBriot
Here is a example:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        cmdDefs = ui.commandDefinitions
        testButton = cmdDefs.addButtonDefinition('TestButton',
                                                'TestButton',
                                                'TestButton',
                                                'resources')
        makePanel = ui.allToolbarPanels.itemById('SolidMakePanel')
        makePanel.controls.addSeparator()
        dropdown = makePanel.controls.addDropDown('TestDrodown', 'resources', 'TestDrodown', '', True)
        button = dropdown.controls.addCommand(testButton)
        button.isPromoted = True
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        cmdDef = cmdDefs.itemById('TestButton')
        if cmdDef:
            cmdDef.deleteMe()
        cntrls = makePanel.controls
        cntrl = cntrls.itemById('TestButton')
        if cntrl:
            cntrl.isPromoted = False
            cntrl.deleteMe()
        cntrl = cntrls.itemById('TestDrodown')
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
When the add-in is stopped, all controls are removed except the promoted button.
Thank you.
Replies (7)
JeromeBriot
Am I the only one to face this issue ?
goyals
I tried with the script you shared but unable to see any issue. Please look at the attached video.
Shyam Goyal
Sr. Software Dev. Manager
JeromeBriot
Thank you @goyals
But I didn't see the promoted button on the animated GIF.
Normaly a "?" button should appear in the SOLID toolbar when you run the add-in.
goyals
I just added the button in SolidCreate panel instead of SolidMakePanel that might be the reason. This is the only change I made in your script.
Shyam Goyal
JeromeBriot
Did you modify the ressource folder? Because a button can only be promoted if it's linked to an icon.
It could explain why we can't see the button on the toolbar in your video.
saurabh.singhKD42F
Hi.
Below code will work fine for deleting the promoted button.
def run(context):
    ui = None
    try:
                                                'TestButton',
                                                'TestButton',
                                                'resources')
    except:
        if ui:
def stop(context):
    ui = None
    try:
        if cmdDef:
            cmdDef.deleteMe()
        cntrl = cntrls.itemById('TestDrodown').controls.itemById('TestButton')
        if cntrl:
            cntrl.deleteMe()
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
JeromeBriot
Thank you @saurabh.singhKD42F
        if cntrl:
            cntrl.deleteMe()
