Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Bug? Unable to delete a button promoted to a panel when its parent is a dropdown
7 REPLIES 7
Message 1 of 8
JeromeBriot
568 Views, 7 Replies
Here is a example:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        cmdDefs = ui.commandDefinitions
        testButton = cmdDefs.addButtonDefinition('TestButton',
                                                'TestButton',
                                                'TestButton',
                                                'resources')
        makePanel = ui.allToolbarPanels.itemById('SolidMakePanel')
        makePanel.controls.addSeparator()
        dropdown = makePanel.controls.addDropDown('TestDrodown', 'resources', 'TestDrodown', '', True)
        button = dropdown.controls.addCommand(testButton)
        button.isPromoted = True
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        cmdDef = cmdDefs.itemById('TestButton')
        if cmdDef:
            cmdDef.deleteMe()
        cntrls = makePanel.controls
        cntrl = cntrls.itemById('TestButton')
        if cntrl:
            cntrl.isPromoted = False
            cntrl.deleteMe()
        cntrl = cntrls.itemById('TestDrodown')
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
When the add-in is stopped, all controls are removed except the promoted button.
Thank you.
7 REPLIES 7
Message 2 of 8
JeromeBriot
in reply to: JeromeBriot
Am I the only one to face this issue ?
Message 3 of 8
goyals
I tried with the script you shared but unable to see any issue. Please look at the attached video.
Shyam Goyal
Sr. Software Dev. Manager
Message 4 of 8
JeromeBriot
in reply to: goyals
Thank you @goyals
But I didn't see the promoted button on the animated GIF.
Normaly a "?" button should appear in the SOLID toolbar when you run the add-in.
Message 5 of 8
goyals
I just added the button in SolidCreate panel instead of SolidMakePanel that might be the reason. This is the only change I made in your script.
Shyam Goyal
Message 6 of 8
JeromeBriot
in reply to: goyals
Did you modify the ressource folder? Because a button can only be promoted if it's linked to an icon.
It could explain why we can't see the button on the toolbar in your video.
Message 7 of 8
Hi.
Below code will work fine for deleting the promoted button.
def run(context):
    ui = None
    try:
                                                'TestButton',
                                                'TestButton',
                                                'resources')
    except:
        if ui:
def stop(context):
    ui = None
    try:
        if cmdDef:
            cmdDef.deleteMe()
        cntrl = cntrls.itemById('TestDrodown').controls.itemById('TestButton')
        if cntrl:
            cntrl.deleteMe()
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
Message 8 of 8
Thank you @saurabh.singhKD42F
        if cntrl:
            cntrl.deleteMe()
Technology Administrators
