Announcements
[Bug] TableCommandInput.minimumVisibleRows runtime error if > 4.
thomasa88
thomasa88
TableCommandInput.minimumVisibleRows cannot be set higher than 4. An error is thrown if I set it to 5.
Reproduce:
* Grab Command Inputs API sample
* Make sure you have the resources: image.png, button, One, Two (I reported the broken link on the webpage)
* Insert "tableInput.minimumVisibleRows = 5" after "addRowToTable(tableInput)" on line 260.
* Run the script
Fusion 360
Failed:
Traceback (most recent call last):
File "C:/Users/Thomas/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Command Inputs API Sample/Command Inputs API Sample.py", line 260, in notify
File "C:/Users/Thomas/AppData/Local/Autodesk/webdeploy/production/b5edf6a9efeacc46b6646b394c91bddfaa2f2d05/Api/Python/packages\adsk\core.py", line 27250, in <lambda>
__setattr__ = lambda self, name, value: _swig_setattr(self, TableCommandInput, name, value)
File "C:/Users/Thomas/AppData/Local/Autodesk/webdeploy/production/b5edf6a9efeacc46b6646b394c91bddfaa2f2d05/Api/Python/packages\adsk\core.py", line 51, in _swig_setattr
return _swig_setattr_nondynamic(self,class_type,name,value,0)
File "C:/Users/Thomas/AppData/Local/Autodesk/webdeploy/production/b5edf6a9efeacc46b6646b394c91bddfaa2f2d05/Api/Python/packages\adsk\core.py", line 44, in _swig_setattr_nondynamic
if method: return method(self,value)
File "C:/Users/Thomas/AppData/Local/Autodesk/webdeploy/production/b5edf6a9efeacc46b6646b394c91bddfaa2f2d05/Api/Python/packages\adsk\core.py", line 27379, in _set_minimumVisibleRows
return _core.TableCommandInput__set_minimumVisibleRows(self, *args)
RuntimeError: 3 : invalid value
OK
nnikbin
It is because the default maximumVisibleRows is 4 and minimumVisibleRows should not be less than maximumVisibleRows. You can set maximumVisibleRows first, then set minimumVisibleRows to any value less than maximumVisibleRows.
nnikbin
For those who do not have the resources folder (because of the broken link) I have attached it to this post (downloaded when the link was not broken).
thomasa88
Ah, that makes sense. Thanks!
