Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Bug: Reversed normal when doing difference with temporory rotated bodies?
1 REPLY 1
JesusFreke
155 Views, 1 Reply
I was doing some design work using temporary brep bodies, and ran into a situation where the normal of a planar face seemed to be inexplicably reversed. I've simplified things into a minimal-ish reproducible example script.
import adsk.core
import adsk.fusion
from adsk.core import Matrix3D, Point3D, OrientedBoundingBox3D, Vector3D
import math
def run(_):
design().designType = adsk.fusion.DesignTypes.DirectDesignType
side = box(10, 6, .75)
side = rx(side, 90)
side = rz(side, 90)
back = box(10, 6, .75)
pin = translate(
box(.5, 2, .75),
-.25, 2, 0)
brep().booleanOperation(back, pin,
adsk.fusion.BooleanTypes.UnionBooleanType)
rx(back, 90)
translate(back,
.5, 10, 0)
brep().booleanOperation(side, back,
adsk.fusion.BooleanTypes.DifferenceBooleanType)
side_occurrence = create_occurrence(side)
translate(back, 2, 0, 0)
create_occurrence(back)
for face in side_occurrence.bRepBodies[0].faces:
# The face we want has an area of 2
if abs(2 - face.area) < .001:
ui().activeSelections.add(face)
print(face.geometry.normal.asArray())
print(face.geometry.evaluator.getNormalAtPoint(face.pointOnFace)[1].asArray())
def app():
return adsk.core.Application.get()
def design():
return adsk.fusion.Design.cast(app().activeProduct)
def ui():
return app().userInterface
def root():
return design().rootComponent
def brep():
return adsk.fusion.TemporaryBRepManager.get()
def box(x, y, z):
return brep().createBox(OrientedBoundingBox3D.create(
Point3D.create(x/2, y/2, z/2),
Vector3D.create(1, 0, 0),
Vector3D.create(0, 1, 0),
x, y, z))
def translate(body, x, y, z):
translation = Matrix3D.create()
translation.translation = adsk.core.Vector3D.create(x, y, z)
brep().transform(body, translation)
return body
def rotate(body, axis, angle):
transform = Matrix3D.create()
rotation = Matrix3D.create()
rotation.setToRotation(math.radians(angle), axis, Point3D.create(0, 0, 0))
transform.transformBy(rotation)
brep().transform(body, transform)
return body
def rx(body, angle):
return rotate(body, Vector3D.create(1, 0, 0), angle)
def rz(body, angle):
return rotate(body, Vector3D.create(0, 0, 1), angle)
def create_occurrence(body):
occurrence = root().occurrences.addNewComponent(Matrix3D.create())
occurrence.component.bRepBodies.add(body)
return occurrence
This results in the following object, with the offending face selected:
The normal of the selected face is (0.0, -1.0, -2.2204460492503126e-16). However, if you look at the selected face, it's normal is clearly in the positive y direction
As part of trying to create the minimal reproduction, I noticed that I couldn't reproduce the issue if I created the boxes in the correct orientation to begin with. It only occurs if I create them laying down flat, and then rotate them into the correct orientation.
1 REPLY 1
JesusFreke
in reply to: JesusFreke
Nevermind, I just figured it out. I just noticed the BRepFace.isParamReversed property, which is set to indicate the normal from the geometry object is reversed.
I confirmed that isParamReversed is True in this case, and also that face.evaluator.getNormalAtPoint() returns the correct normal. My script was previously using face.geometry.normal, or face.geometry.evaluator.getNormalAtPoint(), both of which are affected by the isParamReversed property
