Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
[Bug?] Inconsistency between Sketch.transform documentation and actual behavior
0 REPLIES 0
Message 1 of 1
nnikbin
110 Views, 0 Replies
Based on Sketch.transform documentation:
it "Gets and sets the transform of the sketch with respect to model space."  and "Setting the transform will fail in the case where the sketch is parametric"
But setting it actually multiplies the existing matrix in the new matrix.
Here is a code block showing this inconsistency:
import adsk.core, adsk.fusion, traceback
def run(context):
    try:
        ui = adsk.core.UserInterface.cast(None)
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des :adsk.fusion.Design = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        baseFeature = root.features.baseFeatures.add()
        baseFeature.startEdit()
        sketch = root.sketches.add(root.xYConstructionPlane)
        matrix1 = adsk.core.Matrix3D.create()
        matrix1.translation = adsk.core.Vector3D.create(2, 0, 0)
        sketch.transform = matrix1
        matrix2 = adsk.core.Matrix3D.create()
        matrix2.translation = adsk.core.Vector3D.create(0, 3, 0)
        sketch.transform = matrix2
        sketch.sketchCurves.sketchCircles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 1)
        baseFeature.finishEdit()
        ui.messageBox(str(sketch.transform.asArray()))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
and the result:
Tags (2)
Labels (1)
  • bug
0 REPLIES 0
