Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Bug in TextBoxCommandInput and StringValueInput inside a table hosted by a group
0 REPLIES 0
Message 1 of 1
nnikbin
190 Views, 0 Replies
Usign TextBoxCommandInput and StringValueInput inside a TableCommandInput which is a child of a GroupCommandInput produces some unexpected behaviours.
For StringValueInput:
Setting isReadOnly to true for StringValueInput will not work if the StreingValueInput is inside a table which is a child of a group.
The following picture shows the problem in a modified version of CustomGraphicsSample add-in (left) versus the original version of the sample add-in (right). The difference is that the modified version uses a group to host the table.
For TextBoxCommandInput:
Using TextBoxCommandInput inside a TableCommandInput which is a child of a GroupCommandInput produces some problems when the number of rows is greater than TableCommandInput.maximumVisibleRows. It actually creates empty a textbox with a small vertical scrollbar for the rows > maximumVisibleRows.
0 REPLIES 0
