Bug in Proxies for Rigid Groups?
I've been trying to suppress all the rigid groups in an assembly like so:
for rigidGroup in rootComp.allRigidGroups:
rigidGroup.isSuppressed = True
unfortunately this doesn't work for secondary occurrences of components.
minimal example here with two instances of a component and a rigid group comprising of the two subComponents:
this is the result after the script runs... the first "Rigid Group 2" is suppressed, while the Rigid Group 2 of the second occurrence Component1:2 does not get affected.
the iteration passes both rigid groups and I've actually checked, that the assemblyContext of them differ to the correct occurrence.
I've also tried to iterate over all of the occurrences and access the rigid group that way:
for occurrence in allOccurrences:
for rigidGroup in occurrence.rigidGroups:
same result. I then tried with this in the inner loop:
rigidGroup.nativeObject.createForAssemblyContext(occurrence).isSuppressed = True
which failed with:
> RuntimeError: 3 : object does not belong to the occurrence's component
Any ideas?
