Announcements
Bug. Impossible to save named view with perspective camera. Resulting camera has very different eye.
soswow
soswow
Here is the simplest code:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
from adsk.core import *
from adsk.fusion import *
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = Design.cast(app.activeProduct)
        camera = app.activeViewport.camera
        camera.perspectiveAngle = math.radians(35)
        design.namedViews.add(camera)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
When I execute this, it creates named view for the current camera position and orientation. But when I click on that view it moves far away from where camera was/is.
So it that was the original position when script is ran:
then after clicking on saved named view it goes way back:
Did some debugging and logging.
# Example of current camera when saving as named view:
current camera details. eye: x: 209.2645 mm, y: -27.2470 mm, z: 97.5599 mm target: x: -8.3656 mm, y: -10.8403 mm, z: 15.7369 mm up_vector: x: -2.7197 mm, y: 4.9824 mm, z: 8.2328 mm
# CAmera that is attached to saved named view
saved view camera details. eye: x: 3442.8070 mm, y: -271.0171 mm, z: 1313.2829 mm target: x: -8.3656 mm, y: -10.8403 mm, z: 15.7369 mm up_vector: x: -2.7197 mm, y: 4.9824 mm, z: 8.2328 mm
Even if I construct camera myself from scratch:
        new_camera = Camera.create()
        new_camera.cameraType = CameraTypes.PerspectiveCameraType
        new_camera.perspectiveAngle = math.radians(40)
        new_camera.isFitView = False
        new_camera.isSmoothTransition = True
        new_camera.eye = camera.eye.copy()
        new_camera.target = camera.target.copy()
        new_camera.upVector = camera.upVector.copy()
        app.activeViewport.camera = new_camera
        design.namedViews.add(new_camera)
It would still stores much farther camera
soswow
Still haven't found a workaround. Except for maybe creating it manually in UI which is not what I incision as a workflow for my plugin..
soswow
It's something to do with it being perspective ...
Look at this:
import math
def run():
    ui = None
    try:
        while design.namedViews.count > 0:
            design.namedViews.item(0).deleteMe()
        for i in range(10):
            fov = 20 + i * 5
            new_camera.perspectiveAngle = math.radians(fov)
            new_camera.isSmoothTransition = False
            new_camera.eye = Point3D.create(0, 0, 10)
            new_camera.target = Point3D.create(0, 0, 0)
            new_camera.upVector = Vector3D.create(0, 1, 0)
            new_named_view = design.namedViews.add(new_camera)
            app.log(f'fov: {fov} with camera.eye.z == 10 named view cameras becomes {new_named_view.camera.eye.z}')
    except:
        if ui:
This generates this:
 fov: 20 with camera.eye.z == 10 named view cameras becomes 8040.859369381589
 fov: 25 with camera.eye.z == 10 named view cameras becomes 5086.622801252298
 fov: 30 with camera.eye.z == 10 named view cameras becomes 3482.0508075688767
 fov: 35 with camera.eye.z == 10 named view cameras becomes 2514.7533975943365
 fov: 40 with camera.eye.z == 10 named view cameras becomes 1887.1580426032576
 fov: 45 with camera.eye.z == 10 named view cameras becomes 1457.1067811865469
 fov: 50 with camera.eye.z == 10 named view cameras becomes 1149.7274830283475
 fov: 55 with camera.eye.z == 10 named view cameras becomes 922.5430830356662
 fov: 60 with camera.eye.z == 10 named view cameras becomes 750.0000000000005
 fov: 65 with camera.eye.z == 10 named view cameras becomes 615.9782027526672
new z changes depending on camera's FOV
in this relationship:
soswow
I am more then sure it is a bug.
kandennti
@soswow -San.
I was curious so I tested it out to try a few things.
# Fusion360API Python script
import traceback
import adsk.core as core
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        vp: core.Viewport = app.activeViewport
        cam: core.Camera = vp.camera
        dumpCam(cam)
        cam.cameraType = core.CameraTypes.OrthographicCameraType
        vp.camera = cam
        dumpCam(cam)
        cam.cameraType = core.CameraTypes.PerspectiveCameraType
        vp.camera = cam # <-error
        dumpCam(cam)
    except:
        if ui:
def dumpCam(cam: core.Camera) -> None:
    dump("","")
    dump("type", cam.cameraType)
    dump("eye",cam.eye.asArray())
    dump("target",cam.target.asArray())
    dump("dist",cam.eye.distanceTo(cam.target))
    dump("perspectiveAngle",cam.perspectiveAngle)
    try:
        returnValue, width, height = cam.getExtents()
        dump(f"{returnValue}:{width}:{height}","")
    except:
        pass
def dump(msg, x) -> None:
    core.Application.get().log(f"{msg}:{x}")
I got an error when switching the camera to Perspective. (ver 2.0.20476)
This used to work before. There seems to be another bug here.
