Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
[BUG] DrawingDocument.isUpToDate always True
0 REPLIES 0
Message 1 of 1
gvisca44
74 Views, 0 Replies
I think the DrawingDocument.isUpToDate property always returns True.
(refer my other recent posts on export drawings to PDF).
Consider the following: (note - I have tried to remove irrelevant code - leaving just whats needed to highlight what I think is an error - so if I've created an error I'm sorry.).
Run the script - You'll be present to choose a drawing file.  Select one that is out of date.  A message will be written indicating the isUpToDate is True (I believe).  Choose one that IS up to date - same message.
If you modify the code and attempt to "updateAllReferences" a fatal error occurs.
import adsk.core
import adsk.fusion
import adsk.drawing
import traceback
app = None
ui = None
def run(context):
    global app, ui
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        drawingFiles:adsk.core.DataFiles = getDrawingFiles()
        adsk.doEvents()
        for drawingFile in drawingFiles:
            #doc:adsk.core.Document = app.documents.open(drawingFile)
            drawingDoc:adsk.drawing.DrawingDocument = app.documents.open(dataFile=drawingFile, visible=True)
            drawingDoc = updateDocReferences(drawingDoc)
            if drawingDoc == None:
                # an error occurred
                return
            adsk.doEvents()
            drawingDoc.close(saveChanges=False)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getDrawingFiles() -> adsk.core.DataFiles:
    cloudDialog = ui.createCloudFileDialog()
    cloudDialog.title = 'Select drawings to export.'
    cloudDialog.isMultiSelectEnabled = True
    cloudDialog.filter = 'f2d'
    dialogResult = cloudDialog.showOpen()
    if dialogResult == adsk.core.DialogResults.DialogOK:
        #dataFolder:adsk.core.DataFolder = cloudDialog.dataFolder
        dataFiles:adsk.core.DataFiles = cloudDialog.dataFiles
        return dataFiles
def updateDocReferences(
    ) -> adsk.drawing.DrawingDocument:
    msg = f'{drawingDoc.name} isUpToDate = {drawingDoc.isUpToDate}'
    app.log(msg)
    adsk.doEvents()
    if not drawingDoc.isUpToDate:
        if drawingDoc.updateAllReferences() == False:
            msg = f'{drawingDoc.name} updateAllReferences failed'
            app.log(msg)
            adsk.doEvents()
            return None
        saveDescription = 'Update references'
        if drawingDoc.save(saveDescription) == False:
            msg = f'{drawingDoc.name} save failed'
            app.log(msg)
            adsk.doEvents()
            return None
        msg = f'{drawingDoc.name}'
        app.log(msg)
        adsk.doEvents()
    return drawingDoc
0 REPLIES 0
