BoolValueCommandInput.isFullWidth
rolandas_vegis
rolandas_vegis
I'm trying to make a button in a command with the BoolValueCommandInput. It has isFullWidth property which as I understand should make the button fill entire width of the dialog (description says so). Setting the property doesn't change the button in any way.
Am I missing something or is this a bug?
marshaltu
I did a quick check. It did have difference when we set the property into "True" and "False". The following snapshot were generated by our CommandInputSample.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97
Marshal
Marshal Tu
Fusion Developer
rolandas_vegis
Yes on your snapshots there is a difference. Could you try again but with a button which has no icon, and is text only?
marshaltu
This is what I am seeing without icon. What's the behaviour you expected for isFullWidth. Please kindly be aware this is a property for base object "CommandInput". So the behaviour may be different for each kind of command input.
Marshal
Marshal Tu
Fusion Developer
rolandas_vegis
Well from the description of the property I expected the button to be stretched, now I see that's now how it works.
Thank you.
fatalbullethit
Curiously, when isFullWidth is set to True the checkbox and state button are aligned left while the click button is not - any way to make the click button align left (or right for that matter), too?
