Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
BOM help, objects?
1 REPLY 1
sstattelman4GLLM
176 Views, 1 Reply
BOM help, objects?
I just have a quick question, is it possible to list a set of bodies within a component in a parts list? If not, is it possible  to make the bodies all into subcomponents and not lose the label and materials I have already set? Thanks in advance.
-Sean
1 REPLY 1
goyals
in reply to: sstattelman4GLLM
May be you can try something like this
app = adsk.core.Application.get()
root  = app.activeProduct.rootComoponent
bodies = adsk.core.ObjectCollection.create()
// child component bodies
for occ in root.allOccurrences:
childComp = occ.component
for body in childComp.bRepBodies:
bodies.add(body)
// root component bodies
for body in root.bRepBodies:
bodies.add(body)
Now bodies contains all bodies present in part. You need to open the part in Fusion before you try this. There are API available to open the document in Fusion in background passing the dataFile object to it. I hope it helps. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
