Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Batch import multiple splines of csv files. And adding a loft between those splines.
4 REPLIES 4
tomas_kramer
247 Views, 4 Replies
It's my first time using the Fusion API. I am using Windows 10 and Python. I want to import multiple splines into the Fusion (which currently works nicely with the "ImportSplineCSV" sample script), but I find it tedious to do for every csv.file. I was wondering if there was a way to select multiple csv files and create a spline for each seperate one.
In this thread i found a solution, i think, but couldnt get the batch import to work.
https://forums.autodesk.com/t5/fusion-api-and-scripts/trouble-with-batch-import-and-loft-of-csv-file...
#Author-Autodesk Inc.
#Description-Import spline from csv file
import adsk.core, adsk.fusion, tracebac
import io
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get all components in the active design.
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        title = 'Import Spline csv'
        if not design:
            ui.messageBox('No active Fusion design', title)
            return
        dlg = ui.createFileDialog()
        dlg.title = 'Open CSV File'
        dlg.filter = 'Comma Separated Values (*.csv);;All Files (*.*)'
        if dlg.showOpen() != adsk.core.DialogResults.DialogOK :
            return
        filename = dlg.filename
        sketches = []
        for i in range(1,202‌‌#Loop for csv import
            filename = 'C:/*privacy*/layer{}.csv'.format(i)
            with io.open(filename, 'r', encoding='utf-8-sig') as f:
                points = adsk.core.ObjectCollection.create()
                line = f.readline()
                data = []
                while line:
                    pntStrArr = line.split(',')
                    for pntStr in pntStrArr:
                        try:
                            data.append(float(pntStr))
                        except:
                            break
                    if len(data) >= 3 :
                        point = adsk.core.Point3D.create(data[0], data[1], data[2])
                        points.add(point)
                    line = f.readline()
                    data.clear()
            if points.count:
                sketch = design.rootComponent.sketches.add(design.rootComponent.xYConstructionPlane)
                sketch.sketchCurves.sketchFittedSplines.add(points)
                sketches.append(sketch)
            else:
                ui.messageBox('No valid points', title)
        loftFeats = rootComp.features.loftFeatures
        loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj = loftInput.loftSections
        for sketch in skethes:
            profile = sketch.profiles.item(0)
            loftSectionsObj.add(profile)
        for j in range(0,100‌‌#Loop for selecting the scetch profiles for the loft
         profile = design.rootComponent.sketches.add(rootComp.xYConstructionPlane).profiles.item(j)
        loftInput.isSolid = False
        # Create loft feature
        loftFeats.add(loftInput)
#design.rootComponent.sketches.add(rootComp.xZConstructionPlane).profiles.item(0)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
After importing the splines, I want to create a loft between the splineprofiles, i wonder if that can be done in the same script. I am working on a propeller and im generating the sectioncurves using openprop v3.3.4. in matlab:
After using the import spline script 20 times i get one blade of the propeller:
Since its always the same process for each propeller, i wonder if its possible to automate the whole process to create a propeller. With the solid loft function iIwant to create a blade. Than i import the hub component and combine the components together. After using a fillet i get a nice transistion between the blades and the hub. With the c-pattern i want to copy the blade with the fillet to the other side.
Thank you in advance and have a nice day,
Tomas
Tags (4)
4 REPLIES 4
BrianEkins
in reply to: tomas_kramer
What you're wanting to do is certainly possible. Here's a script I just wrote that creates a spline for each CSV file in a specified folder and then creates a loft through the splines. I've attached the CSV files I used for testing. You should be able to find other posts and examples to add the additional code to insert the hub, mirror the blade, and combine them into a single body. Hopefully, this provides a good start.
def run(context):
    ui = None
    try:
        if app.activeProduct.productType != 'DesignProductType':
            ui.messageBox('A Design must be acitve.')
            return
        des: adsk.fusion.Design = app.activeProduct
        root = des.rootComponent
        # Prompt to have the folder containing the csv files selected.
        dlg = ui.createFolderDialog()
        dlg.title = 'Section Curves Folder'
        if dlg.showDialog() != adsk.core.DialogResults.DialogOK :
            return
        sectionFolder = dlg.folder
        # Create a new sketch for the sections.
        sk = root.sketches.add(root.xYConstructionPlane)
        sk.name = 'Section Curves'
        # Get all of the csv files.
        files = [f for f in os.listdir(sectionFolder) if f.endswith('.csv')]
        files.sort()
        sections = []
        for file in files:
            fullFilename = os.path.join(sectionFolder, file)
            firstLine = True
            with open(fullFilename, 'r') as file:
                reader = csv.reader(file)
                for row in reader:
                    if firstLine:
                        # Strip off the byte characters at the beginning of the file.
                        row[0] = row[0][3:]
                        firstLine = False
                    points.add(adsk.core.Point3D.create(float(row[0]), float(row[1]), float(row[2])))
            if points.count > 1:
                curve = sk.sketchCurves.sketchFittedSplines.add(points)
                sections.append(curve)
            else:
                point = sk.sketchPoints.add(points[0])
                sections.append(point)
        loftInput = root.features.loftFeatures.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        for section in sections:
            if section.objectType == adsk.fusion.SketchPoint.classType():
                loftSection = loftInput.loftSections.add(section)
                loftSection.setPointTangentEndCondition(adsk.core.ValueInput.createByReal(1))
            else:
        loft = root.features.loftFeatures.add(loftInput)
    except:
        if ui:
Brian Ekins
tomas_kramer
Files:
tomas_kramer
in reply to: BrianEkins
Thank you so much for your help!
Ive tried the code and I thought it was allready amazing, but than I found out it failed to make a spline:
I've tried to understand how it works, but the code seems fine, so i dont know what the problem is. I've provided my csv files too which i used for testing, maybe it helps
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback, os, csv
def run(context):
    ui = None
    try:
            return
            return
        files.sort()
        sections = []
        for file in files:
            firstLine = True
                for row in reader:
                    if firstLine:
                        row[0] = row[0][3:]
                        firstLine = False
#create spline part:
            if points.count > 1:#check if there 2 points to create a spline
            else:# If there's only one point, add it as a sketch point
            else:
    except:
        if ui:
@BrianEkins
BrianEkins
Your files are encoded differently than mine, so it worked for me and not for you. My files, which I created using Excel, had extra characters at the beginning of the file to specify the encoding type used for the file. I was assuming all files had this same encoding, so I was always ignoring the first three characters. I changed the code, so instead of blindly assuming there are encoding characters at the beginning of the file, I now specify the encoding when opening the file and let Python take care of it.
After fixing that, the loft was failing with your data. The problem is that the files must be named alphabetically in the order they're processed.
They were being processed:
SectionCurve1.csv
SectionCurve10.csv
SectionCurve11.csv
SectionCurve12.csv
SectionCurve13.csv
SectionCurve14.csv
SectionCurve15.csv
SectionCurve16.csv
SectionCurve17.csv
SectionCurve18.csv
SectionCurve19.csv
SectionCurve2.csv
SectionCurve3.csv
I renamed the single digits, so the first files are now SectionCurve01.csv, SectionCurve02.csv, etc. Now, they're in correct alphabetical order.
Here's the modified program. I've also attached the files for the renamed sections.
import adsk.core, adsk.fusion, traceback
import os
import csv
def run(context):
    ui = None
    try:
            return
            return
        files.sort()
        sections = []
        for file in files:
            with open(fullFilename, 'r', encoding = 'utf-8-sig') as file:
                for row in reader:
                curve = None
            else:
            else:
    except:
        if ui:
Brian Ekins
