Announcements
Auto generate Setup and NC Output
patrikrump
patrikrump
Dear Fusion Community,
I have tried to write a code where a setup and a NC output is always created for each visible body.
Currently only setup and NC output should be created and named.
Unfortunately this does not work although no error is displayed. Can you perhaps help me with this?
Thank you very much
import adsk.core
import adsk.fusion
import traceback
def run(context):
    try:
        # Zugriff auf die aktive Fusion 360-Anwendung
        app = adsk.core.Application.get()
        ui = app.userInterface
        # Zugriff auf das aktive Design
        design = app.activeProduct
        if not design:
            ui.messageBox('Kein aktives Design gefunden. Bitte auf die Konstruktions Seite wechseln')
            return
        # Zugriff auf die aktive Komponente
        root_comp = design.rootComponent
        # Zugriff auf alle sichtbaren Körper im Design
        bodies = root_comp.bRepBodies
        for body in bodies:
            # Erstelle ein Setup für jeden Körper
            setup_name = f'Setup_{body.name}'
            setup = root_comp.manufacturingSetups.addMillSetup(body, setup_name)
            # Setze den Namen des Körpers als Setup-Namen
            setup.name = body.name
            # Erstelle eine NC-Ausgabe mit dem Körpernamen
            nc_program_name = f'NC_{body.name}'
            nc_program = setup.createNCProgram(root_comp, nc_program_name)
        ui.messageBox('Setups und NC-Ausgaben wurden erfolgreich erstellt.')
    except Exception as e:
        ui.messageBox('Fehler aufgetreten:\n{}'.format(traceback.format_exc()))
run(None)
CGBenner
@patrikrump
Welcome to the Community.
I noticed that your code is in German.  If you would feel more comfortable, I can move this post to the German Fusion forum.  If you are happy to communicate in English, I can leave it here.  Whatever you prefer.  🙂
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
patrikrump
I don't care about the language.
It's just important to me that many people see it because of the possible help
a.laasW8M6T
Hi
This is probably best asked in the API Forum:
https://forums.autodesk.com/t5/fusion-api-and-scripts/bd-p/22
patrikrump
Thank you for moving my post.
unfortunately I have not yet found a solution
kandennti
Hi @patrikrump -San.
I believe that would be made by chatGPT, etc. It is a pretty disappointing code.
I created a basic sample.
Setup and NC program for each body shown. It is still lacking in functionality.
This can be done from the design workspace.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
import sys
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        camObj: cam.CAM = get_cam_product()
        rootOcc: fusion.Occurrence = camObj.designRootOccurrence
        bodies = get_show_bodies(rootOcc.component)
        if len(bodies) < 1: return
        for body in bodies:
            create_nc_program(
                camObj,
                create_setup(
                    camObj,
                    body
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_nc_program(
        camObj: cam.CAM,
        targetSetup: cam.Setup,
) -> cam.NCProgram:
    ncPrograms: cam.NCPrograms = camObj.ncPrograms
    ncIpt: cam.NCProgramInput = ncPrograms.createInput()
    ncIpt.displayName = targetSetup.name
    set_cam_parameter(
        ncIpt,
        "nc_program_filename",
        targetSetup.name,
    set_cam_parameter(
        ncIpt,
        "nc_program_openInEditor",
        True,
    ncIpt.operations = [targetSetup]
    ncPrograms.add(ncIpt)
def get_show_bodies(
        root: fusion.Component
) -> list[fusion.BRepBody]:
    bodies = root.findBRepUsingPoint(
        core.Point3D.create(0,0,0),
        fusion.BRepEntityTypes.BRepBodyEntityType,
        sys.float_info.max,
        True,
    return list(bodies)
def create_setup(
        camObj: cam.CAM,
        targetBody: fusion.BRepBody,
) -> cam.Setup:
    setups: cam.Setups = camObj.setups
    setupIpt: cam.SetupInput = setups.createInput(
        cam.OperationTypes.MillingOperation
    setupIpt.models = [targetBody]
    setup: cam.Setup = setups.add(setupIpt)
    setup.name = targetBody.name
    set_cam_parameter(
        setup,
        'job_stockMode',
        'default',
    set_cam_parameter(
        setup,
        'job_stockOffsetMode',
        'keep',
    return setup
def get_cam_parameter(
        camEntity,
) -> cam.CAMParameter:
    try:
        prm: cam.CAMParameter = camEntity.parameters.itemByName(
            name
        if not prm: return None
        return prm.value.value
    except:
        return None
def set_cam_parameter(
        camEntity,
        value: str,
) -> bool:
    try:
            name
        if not prm: return False
        prm.value.value = value
        return True
    except:
        return False
def get_cam_product() -> cam.CAM:
    activete_cam_env()
    return app.activeProduct
def activete_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
patrikrump
kandennti thank you so much for this great help,
The code does what it should, I have to create the appropriate edits depending on the requirements of the furniture.
I have an average of 8 to 12 setups per piece of furniture, so this work is very annoying. Thanks to your script I can concentrate on the work and not on the organization.
Thank you very much
