AttributeError: 'NoneType' object has no attribute 'cast'
YouElz
YouElz
Hi all
Does anyone know why I am getting this error?
Failed:
Traceback (most recent call last):
  File "C:/Users/YouElz/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/NewScript2/NewScript2.py", line 11, in run
    design = adsk.fusion.Design.cast(app.activeProduct)
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        ui.messageBox('Hello script')
    except:
        print('Failed:\n{}'.format(traceback.format_exc()))
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
j4n.vokurka
what workspace is active in the document when you call this script?
this should return a string which defines in which workspace you are:
product = app.activeProduct
productType = product.productType
If the value does not match with one of these, I would expect the error you reported to occur.
YouElz
Thank you for the reply.
I was in the design workspace.
I restarted Fusion and VSCode then debug and it worked... not sure what happened.
