Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Attribute Error(name) while adding bodies from a collection to a component.
2 REPLIES 2
217 Views, 2 Replies
This is a pretty simple script (or so I thought..), based on  a sample script to copy bodies.
So I create a collection of all bodies from all components, to then add them to a component I create from the API.
I get this error:
2020-02-24 12_37_31-Autodesk Fusion 360 (Personal - Not for Commercial Use).png
Here is the script:
# The goal is to copy bodies from a full assembly into a new component, so that it will be possible
# to export as STL from Fusion with a common origin (and axis)
# Beginning on 23/2/2020 @18:59 by BG
# The original sample script seems pretty close to what is needed. I need to be able to select the component I want (must be empty),
# instead of the root.
# the script creat a duplicate, have to remove it.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get active design
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        # Get root component in this design
        rootComp = design.rootComponent
        # Create a collection to store our bodies
        sourceBodies = adsk.core.ObjectCollection.create()
        occs = rootComp.occurrences
        # add all bodies from all components in the collection
        for occurence in occs:
            for body in occurence.bRepBodies:
                sourceBodies.add(body)
                adsk.doEvents()
        newComp = occs.addNewComponent(adsk.core.Matrix3D.create())
        newComp.component.name = rootComp.name + " for STL Export"
        adsk.doEvents()
        newComp.features.copyPasteBodies.add(sourceBodies)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thanks for you help, and best regards.
Bernard
2 REPLIES 2
kandennti
Hi @Anonymous .
The return value of addNewComponent was Occurrence.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-8c7da023-bfd1-4816-9a57-a90dfcf3acd4
Therefore, it worked correctly in this way.
                # adsk.doEvents()
        newOcc = occs.addNewComponent(adsk.core.Matrix3D.create())
        newOcc.component.name = rootComp.name + " for STL Export"
        # adsk.doEvents()
        newOcc.component.features.copyPasteBodies.add(sourceBodies)
It's a confusing method name ...
in reply to: kandennti
ha! 🙂 I knew it had to be easy, but would never have guessed on my own. Thanks!
