Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Assembly traversal using recursion API Sample - Adding "Instances", "Description", "Material" & "Description"
1 REPLY 1
isocam
96 Views, 1 Reply
Can anybody help?
Please see the following website for the "Traverse Assembly" sample:
Fusion 360 Help | Assembly traversal using recursion API Sample | Autodesk
Does anybody know how to add "Instances", "Description", "Material" & "Parent Folder" to the output?
Many thanks in advance!
Kind Regards
Darren
1 REPLY 1
Jorge_Jaramillo
in reply to: isocam
Hi @isocam ,
It could be something like this:
def traverseAssembly(occurrences: adsk.fusion.Occurrences, currentLevel: int, inputString: str, parent: str = '') -> str:
    for i in range(occurrences.count):
        occ = occurrences.item(i)
        materials = [body.material.name for body in occ.bRepBodies if body.material]
        inputString += f"{' '*(currentLevel * 5)}{occ.name};{occ.childOccurrences.count};{occ.component.description};{materials};{parent}" + "\n"
        if occ.childOccurrences:
            inputString = traverseAssembly(occ.childOccurrences, currentLevel + 1, inputString, occ.fullPathName)
    return inputString
I use a semicolon here to separate data items.
Hope this help.
Jorge
