Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Are NamedViews available thru the API ?
2 REPLIES 2
info83PHN
147 Views, 2 Replies
My Design has an existing NamedView, positioned at a specific angle from the model body.
Can I change to that view using the API ( instead of the top, left, bottom, etc )
2 REPLIES 2
info83PHN
in reply to: info83PHN
I found what I needed - didn't need a Named View for my current needs - used '
IsoBottomRightViewOrientation
Will leave the question open in case there is an option for named views
kandennti
