Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
arc direction with addByThreePoints?
2 REPLIES 2
niklaskp
359 Views, 2 Replies
Is there any way to set the direction of the arc when drawing an arc with addByThreePoints? I have the problem of it drawing the arc to the wrong direction and not having any way of knowing when it's right or not, it is kinda taking the long path instead of the short one.
2 REPLIES 2
niklaskp
in reply to: niklaskp
ok, its doing the right thing. My math was bad.
frankzhang
You can change the start point and point along the arc to get expected arc, see below image for reference.
