Hi @Andy_rapid-ood .
We have created a sample that creates images of duplicate combinations of five randomly selected appearances.
With two bodies created in the root component, run the following script
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import random
import itertools
import pathlib
EXPORT_DIR = pathlib.Path(r'C:\temp')
def run(context):
ui = adsk.core.UserInterface.cast(None)
try:
app: adsk.core.Application = adsk.core.Application.get()
ui = app.userInterface
des: adsk.fusion.Design = app.activeProduct
root: adsk.fusion.Component = des.rootComponent
body1: adsk.fusion.BRepBody = root.bRepBodies[0]
body2: adsk.fusion.BRepBody = root.bRepBodies[1]
vp: adsk.core.Viewport = app.activeViewport
appearances = getUniqueAppearances()
appearances_combination = list(itertools.combinations_with_replacement(appearances, 2))
for idx, apps in enumerate(appearances_combination):
body1.appearance = apps[0]
body2.appearance = apps[1]
path = EXPORT_DIR / f'{idx}'
vp.saveAsImageFile(str(path), 0, 0)
ui.messageBox('Done')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getUniqueAppearances() -> list:
try:
appearances: adsk.core.Appearances = app.materialLibraries.itemById(
'BA5EE55E-9982-449B-9D66-9F036540E140').appearances
appearanceLst = [a for a in appearances]
return random.sample(appearanceLst, 5)
except:
return []
I could not find a way to get the appearance folders in the API.
