Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Appearance.addByCopy is still fuzzy
2 REPLIES 2
VismantasKizelis
206 Views, 2 Replies
Hello.
Some time ago I've posted this about malfunction of Appearance.addByCopy. The issue was fixed in November 28, 2018 Product Update. However, I'm still facing some problems about copying appearances. The thing is, that when I try to make a copy of existing appearance in design, then source appearance disappears.
The py script is:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
materialLibs = app.materialLibraries
matLib = materialLibs.item(1)
appear = matLib.appearances.item(0)
des = adsk.fusion.Design.cast(app.activeProduct)
appear1 = des.appearances.addByCopy(appear, "A")
#Having appearance named "A" in desing
#Let's make copy of appearance "A" and name it "A1"
appear2 = des.appearances.addByCopy(appear1, "A1")
#Having appearance named "A1" in desing. Appearance "A" disappeared!!!
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
2 REPLIES 2
goyals
in reply to: VismantasKizelis
I agree it is not working if you try to add an another copy from already copied appearance but the fix is working for below code. Ideally solution should worked for all the combinations but not sure if it is really a blocker.
appear2 = des.appearances.addByCopy(appear, "A1")
Shyam Goyal
Sr. Software Dev. Manager
VismantasKizelis
in reply to: goyals
Unfortunately I have an error with your suggested solution.
After some research I find out that the problem appears when using custom created appearance library. The key is not to have appearance asset in design with same name as it exists in library.
Steps to reproduce:
  1. Using Material Browser create new library "testLib";
  2. Create new appearance "testAppearance" in that lib (I created wood appearance. Don't know if it depends on type)
  3. Run the script:
matLib = materialLibs.itemByName("testLib")
appear = matLib.appearances.itemByName("testAppearance")
des.appearances.addByCopy(appear, "testAppearance") #copy asset by providing original name
des.appearances.addByCopy(appear, "testAppearance_1") #InternalValidationError : assetInst
To make my code work for now I just check appearances in design before copying a new one from library. If appearance with same name is found, then I just rename it in design. Not the most elegant solution, but it works.
