Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
API won't delete sketchText
4 REPLIES 4
erik
384 Views, 4 Replies
I have an issue regarding the deleting of sketchText.
Maybe I made a mistake in my code or misunderstood the API.
I am currently trying to delete all sketchText in a sketch, but the API throw an exception when trying to run a deleteMe method.
To test it I am currently just trying to delete the first sketchText in the sketch.
This is my code:
sketchText = adsk.fusion.SketchText.cast(_destinationSketch.sketchTexts.item(0))
_ui.messageBox(str(sketchText.height) + '\n' + sketchText.text + '\n' + str(sketchText.deleteMe))
sketchText.deleteMe()
This is my messageBox:
And this is my error:
If anyone has a solution or advice it would be appreciated! 🙂
- Erik
4 REPLIES 4
marshaltu
in reply to: erik
Thank you for reporting the issue to us. It was an API bug and has been logged as UP-36835 in our internal system.
There is a workaround for you right away. You can delete a sketch by deleting one of its boundary lines. Please refer to the following codes.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootComp = design.rootComponent;
        sketch = rootComp.sketches.item(0)
        for text in sketch.sketchTexts:
            lines = text.boundaryLines
            lines.item(0).deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
erik
in reply to: marshaltu
Oh, thats why.
Thank you for providing the workaround.
Is this a permanent workaroung and will there be sent a notification when the fix is implementet?
- Erik
marshaltu
in reply to: erik
We will update the thread once the issue gets fixed. Ideally the workaround should keep valid.
Marshal
Marshal Tu
Autodesk, Inc.
erik
Thank you!
